396 Lights Draw
- 650Guy
- Captain
- Been thanked: 35 times
396 Lights Draw
I came across this as my boat has a freedom lift on the back and when it is in use, the lights dim to almost nothing and radio cuts out (indicating a dead battery to me). Battery is new 2019, so wondering if I either have bad batteries, bad charger, short someplace, or a lack of knowledge on how to run stuff. New boat and all there is ALWAYS something to learn!
- Has thanked: 580 times
- Been thanked: 1210 times
Re: 396 Lights Draw
Each old style light could be as much as 10 watts draw at 12 volts.......so 10x how many lights.....then your charger will try to recharge the battery or bank whatever you have there.......looks like you may have some investigation to do.
You may just not have enough capacity....does the lift suggest you have the engines running while operating ?
Edit.....dummy me I wrote amps instead of watts....thanks Tom
- Has thanked: 324 times
- Been thanked: 595 times
Re: 396 Lights Draw
I assume your 35 amp reading is 120 volt unless you have an inverter/ charger that reads 12v loads
If so it's the charger drawing the current. 35 is really high for a charger. Maybe turn off battery charger breaker and find your base load. Maybe water heater or fridge also on.
- 650Guy
- Captain
Re: 396 Lights Draw
Tom your correct, the 35 am reading is on the 120volt side. The charger its self is much lower (Maybe 15-20 amps?). I could watch the amps drop as I turn off each rooms lights, which leads me to believe that's just normal for the lights... the lift really is what has me thinking. Man that thing draws some power!
As far as the engines running during Lift operation, I don't see anywhere in the manual that would indicate such? the lift is wired into the house batteries so I wouldn't THINK the engines would support that much? I could be wrong... and have been before!! HAHA..
Re: 396 Lights Draw
- buster53
- Been thanked: 262 times
Re: 396 Lights Draw
If you turned on all the 12v electrical lights on your boat, it shouldn't pull more than a few amps at most to power up your battery charger.
As far as 12v lights go, do yourself a favor and replace all with LED's. No need to replace the entire fixture, just the bulbs. They use about 1/10 the power of your standard halogen and the heat output is considerably less.
I bought LED equivalents from Amazon for about $13 for a 10 pack. I measured the heat output. My halogens were in the 200 degree range and my LED's were down around 120
- 650Guy
- Captain
Re: 396 Lights Draw
- buster53
Re: 396 Lights Draw
- 650Guy
- Captain
Re: 396 Lights Draw
- Been thanked: 1043 times
Re: 396 Lights Draw
I'd also check the connections on the battery to make sure they're clean and tight. The fact that lights dim to nothing and the radio cuts out means you either have a bad connection somewhere or the battery is discharged or bad.
And definitely upgrade to LEDs. It will save you a lot of current when you need to be on battery power alone and you can adjust the color temperature and the brightness of the bulbs to get the ideal lighting. I was able to go much brighter in my salon with the new bulbs which makes reading much easier, but have smaller bulbs in the aft and v-berth sleeping areas.
