Does a body know if this exhaust nozzle is a factory set up? I have 260 mercs with 4” to 3” exhaust hose on-each manifold they run to mufflers then out the transom to these nozzles that direct the exhaust into the water. Im only making 3000 rpm and am wondering if this is causing excess back pressure. I have gone through fuel system. Carbs and timing.
JJ
3297 mariner exhaust
- Jjwyc
- Vessel Info: 1986 mariner 32
- Has thanked: 3 times
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: 3297 mariner exhaust
I've seen that style of exhaust on several other boats so I think it is a normal type of exhaust.
- Been thanked: 1312 times
Those are.....Davis thru hull exhaust....had em on our 28 Mariner....should be no problems there.
