Locate breaker on 1986 36 Mariner?
Topic author - Scurvy Dog
- Vessel Info: 1986 36 Mariner 3697
Mercruiser 454's - Location: Kenosha, WI
Thanks!
Great Laker
1986 Mariner 3697
- Has thanked: 58 times
- Been thanked: 446 times
Re: Locate breaker on 1986 36 Mariner?
then under that another 115 AC panel. According to the surveyor there must be another breaker in-line between the panel and the shore power plug.
If that breaker is tripped, it would explain why the panel shows no power to that circuit.
But I haven't had time to try and follow the wiring harness because the sale isn't final and the boat is stored in a heated out building the seller owns. If I get a better pic, I'll try to post it after we do the compression test on Wednesday. I'd expect your panel and mine to be nearly the same since they're only one model year apart. But then, stranger things have happened!
Thanks for the feedback Fred.
Great Laker
1986 Mariner 3697
Thanks!
Great Laker
1986 Mariner 3697
This should be an easy fix. Could simply be the cord or the dock connection.
The survey and compression tests went well. Have decided to move forward with purchase. Thanks for the input Fred.
Marsh
Great Laker
1986 Mariner 3697
