Blocking for Storage
Has thanked: 455 times
Been thanked: 1671 times
Re: Blocking for Storage
Postby Viper » October 6th, 2019, 9:36 am
It'll only take one winter for things to go wrong if the ground is unstable just before and after winter. Every area is different but you'd be surprised how much movement that can be. I've dealt with stands that had to be unwound with a sledge hammer because they got too tight, and some that don't do a thing because the ground has dropped leaving several inches of space between the hull and the stand. With a stand, that can be remedied quickly, with blocks, you can shim a gap but if it goes the other way, it'll be a pain to remove a block safely and without damaging the hull.
tomschauer wrote:Source of the post.... make sure all of your interior doors are open, as they will bind.
++1
Pontoon houseboats are notorious for having that problem because of the way they get blocked. It's also not uncommon to find bent structural beams from years of flexing on land.
Take pictures of all your windows to prove that none were cracked prior to this point. If she flexes enough, one or more will crack.
Send the pic to Carver Service and see what they say as some OEMs will have diagrams of the blocking points for different models, which by the way have always been the keel that I've seen. Even if they say those points alone are okay to support the weight of the vessel, the concern is how will ground movement affect that since the sides are bearing all the weight rather than simply steadying her. If they tell you that she must be set on her keel, get it in writing, take it to the marina and insist they remedy it properly. That means lifting her and setting her keel on blocks, not simply shimming blocks under her now.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 474 times
Been thanked: 201 times
Postby pepmyster » October 6th, 2019, 12:17 pm
I take back my opinion.
Has thanked: 579 times
Been thanked: 1210 times
Postby bud37 » October 6th, 2019, 2:30 pm
A little story here.......We had our first Carver that came with it's own factory shipping/storage cradle..weighed a ton... :censored: .....well the first winter we stored it on that cradle thinking that was the best...... this boat had a transom door and a few weeks after sitting on the cradle the door would not close right.....in the spring about an hour after the boat hit the water the door worked just fine again.
Needless to say a lesson learned, bought blocks and had stands made.....we did all our own lift out/in/blocking work ourselves at the time....it never happened again......I know , I know another old guy tale.... :-D
Dusty Bilges
Vessel Info: Carver 300 Sedan
Has thanked: 20 times
Been thanked: 8 times
Postby Dusty Bilges » December 7th, 2019, 7:01 pm
In case anyone is interested the marina owner drove his lift over the tops of two houseboats that were in the row I was in; picked up my boat; put three keel stands under keel and set it back down again; and used the wood blocks on the four corners just to keep it from leaning. No charge. Good guy. Good marina. He likes me - maybe because every time I fill up with gas its a four-hundred dollar event.
Postby Viper » December 8th, 2019, 9:45 am
Excellent, thanks for following up. Good on them for taking the extra time and expense to satisfy a customer. :down:
Dusty Bilges
Postby Dusty Bilges » May 23rd, 2021, 6:20 pm
In case anyone's interested I bought three keel jack stands ($168 each!), and the yard redid it.
Postby Viper » May 23rd, 2021, 10:16 pm
Thanks for keeping us in the loop :down:
Users browsing this forum: No registered users and 64 guests
