Removing wood plate
- 3807Guy
- Vessel Info: 1987 Carver 3807 Model.
Removing wood plate
Has anyone replaced the wood plate that holds down the head. What type of screws are under the plugged holes?
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
Re: Removing wood plate
They should be philips head wood screws.
Kenny
T-Merc 350 Mag MPI (300hp)
- Been thanked: 492 times
To remove the teak plug, simply get a wood screw and driver and screw the wood screw into the center of the plug.
The plug will climb up the ramps of the screw.
Then go in the hole with a small screwdriver and clean any extra debris out.
Do what you have to do with the board, and upon reassembly, put some adhesive in the hole (just a little) and drive the plug lightly into the hole.
Then after the glue drives, take a clean sharp wood chisel and whittle away the excess.
It will look as new.
