444 bait well pump?
Pete
Vessel Info: 2001 Carver 444 diesels
Has thanked: 56 times
Been thanked: 15 times
444 bait well pump?
Post by Pete »
Looking for clarification:
Originally the surveyor said it was my waste discharge pump fitting that was corroded and now on the written survey they are calling it a bait well pump inlet.
I did not know there was a bait well. Here is what was written:
The bait well pump inlet port is significantly corroded; the pump is not operational – suggest renewing pump (Note: if there is no need for a bait well pump, suggest fitting a wash-down pump instead)
Any insight would be appreciated, I sent an email asking for clarification but wanted a second opinion. Thanks!
2001 444
The best way to improve your memory is to do unforgettable things.
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Re: 444 bait well pump?
Post by Tireless »
The hose looks too small to be a sewage discharge pump. If you don't have a live bait well, then use the through hull and hose for some else. If your boat is like mine, I have two fresh water wash downs, but a sea water wash down may come in handy. Just a thought.
Greg
Pete
Post by Pete »
Here is the surveyor's explanation, I wish I got my eyes on what they are talking about.
Sorry for the confusion. The existing pump is a low-pressure pump, with outlet on the outboard side of the transom and a push-pull type switch inside the transom locker. The live bait tank is no longer there. The aft holding tank pump is still there and operational, switch is in the lazarette.
2001 444
Post by tomschauer »
I believe I would have to investigate. Follow the hoses. If it was indeed at one time a baitwell pump and there is no longer a baitwell, why would you replace it? If this is the case one end will go to a through hull below the water line and the other should be going to nowhere.
If it is a holding tank discharge pump, One end will go to the holding tank and the other to a though hull most likely above the water line.
It could also be a wash down pump.
Either way, I would chase it down, as it looks like it may be ready to cut loose.
Pete
Post by Pete »
I believe the surveyor mentioned that the valve was closed off mitigating that fitting from leaking, but that was not clear as I was envisioning a waste discharge, not a bait well setup. I'm going to try and get back on the boat this week and dig deeper, I need to know.
2001 444
