Range Exhaust Blower
DanM
Vessel Info: Carver 396
Has thanked: 5 times
Been thanked: 33 times
Postby DanM » February 18th, 2015, 8:44 pm
Needed to add a cook top exhaust blower without tapping into the cabinet space above. Off the shelf versions would not work due to dimensions and location of exhaust ports so I came up with this.
Dan
Carver 396
SugarSand Tango
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Re: Range Exhaust Blower
Postby AaHubb » February 19th, 2015, 8:13 pm
Interesting. What did you use for a fan and how well does the setup work?
'99 404 CPMY
SeaDragon
DanM
Postby DanM » February 20th, 2015, 8:01 pm
I used a 3" Attwood bilge blower. It does a respectable job. Certainly not as good as the unit at home working through 8" ducts but it moves quite a bit of air and, except for a screw head I did not intrude on the cabinet above. I can tell you that using smothering candles at pan level it worked very well to evacuate the smoke. I have not been able to cook anything since the boat is on the hard.
Technical specifications state that "In system" the blower is rated at 90 cfm. However, with some of the additional installation restrictions it's actually moving less than that but still, it is a welcome addition over the previous passive flow towards the companion way on the other end of the saloon.
Dan
Carver 396
SugarSand Tango
