Forward state room matress size
- Gary Rose
- Vessel Info: 2000 356 carver aft
- Has thanked: 5 times
- Been thanked: 3 times
Can anyone tell me if the forward state room matress a full, queen, or double. Size??????
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Forward state room matress size
Boat beds are almost never the size of a standard home bed. I have the same boat and while I have never measured either berth, my guess is they are both slightly smaller than a standard double. And I might add, they are almost never an exact rectangle. Curved corners, V shaped, even trapezoid shaped sometimes which is a good example of the 356 forward berth.
- Been thanked: 1312 times
Here is a link to the 2000 brochure... they might have the size for your boat in the pages...
https://carveryachts.blob.core.windows. ... 9/2000.pdf
- Been thanked: 654 times
are you looking for new sheets or new mattress?
If looking for a new mattress, either it needs to be custom made, or you can get a queen size memory foam or latex mattress and cut it to fit. The one end will most likely be about an inch wider than a queen, the other end an inch or two narrower than a full. I used a latex queen and cut to fit for my 1998 355, I believe your bed is almost the same.
