Transmission/Damper Plate Noise
riwanika
Vessel Info: 1988 Carver 3207 Aft Cabin
Postby riwanika » May 11th, 2020, 6:14 pm
Can anyone confirm if this sounds like a failed damper plate? Please see the link below to my video:
https://photos.app.goo.gl/STsoZZ6n4WuqkvUP6
The following has been done and checked:
Timing
Mixture
Idle Speed
Operating Temperature
Engine Oil Level
Engine Coolant Level
Transmission Fluid Level
Shaft Alignment to .003
Packing Gland Drip Set to 1 drip per 30s intervals in gear
I'm so tired of beating my head against the wall with this boat and I would like to get it running. My daughter is due in October and I need to get some of these things wrapped up before she gets here!
Has thanked: 455 times
Been thanked: 1671 times
Re: Transmission/Damper Plate Noise
Postby Viper » May 11th, 2020, 7:19 pm
Before you do anything else, I'd say you have a runability issue that you have to solve before you go any further. I'd say most of that sound will likely go away once the engine is running smoothly. That's what it sounds like to me. Maybe the other guys will pick up on something else.
When was the last time you had an ignition tune-up, replacing all the parts?
How old is the fuel and fuel filter? Any water in it?
I'm assuming this was in neutral?
Alaska 530 Voyager
Has thanked: 42 times
Been thanked: 33 times
Postby Alaska 530 Voyager » May 11th, 2020, 8:12 pm
Does that sound go away if you idle up a bit? It does sound like a dampener plate to me.
riwanika
Postby riwanika » May 11th, 2020, 9:00 pm
Alaska 530: It was so bad I didn't want to rev it and risk damage. With the transmission in neutral the engine revs freely all the way up to the rev limiter and sounds amazing. As soon as it's popped into gear I get the rocks rolling around noise just like in the video
Viper: all ignition parts are brand new, plugs, wires, cap, rotor, it has electronic ignition so no need for points and gap settings. Fuel is fresh fuel filter has been replaced and no water in the fuel. The video shown was in forward gear at the very end it was popped into neutral and you can hear the engine running smoothly at appx. 800rpm
Has thanked: 579 times
Been thanked: 1210 times
Postby bud37 » May 11th, 2020, 9:51 pm
How does the engine run under load ? I would try to avoid revving the engine at the dock unloaded....damage can result from water ingestion and any engine can rev smoothly even with a dead cylinder, with no load.
It does seem to have a knock to it....kinda hard to pick it up clearly though from the video sound.
riwanika
Postby riwanika » May 12th, 2020, 1:00 am
bud37 the engine runs great, I only recently started having these issues. I had a rear main seal leak and pulled the engine and trans apart to replace the seal, then reinstalled it all only to find the rear main seal was the wrong one, so apart it came again and went back together. The knock/tick sound could be the loose exhaust clamp that was right by my camera allowing a little bit of exhaust/water to escape. I just finished an alignment that day and started it up only to hear that god awful sound coming from what sounded like either the transmission or the flywheel area. Needless to say I was pretty bummed out.
Postby Viper » May 12th, 2020, 7:19 am
I listened to it again, maybe it's me but I still hear something that indicates she's not running quite right but without being there, it's hard to say for sure but I hear a couple of hesitations. You could actually see the hesitation in the flywheel unless that's you putting it in and out of gear a few times. To be sure, put a mark on it and shoot a timing light on it or the timing plate and see if the mark moves or remains steady in the same place. If she's not running right, you'll get a tranny chatter at low rpm, same as a bad damper.
Revving up in neutral ok doesn't mean that much to me, that's easy to do and sound normal with no load. FWIW, you should not run at high rpm in neutral, you could damage the engine at that rpm with no load.
The damper plate is a possibility for sure but what I'm trying to convey is that you make sure the engine is running properly before condemning the plate and going through the work involved to replace it. Many have been fooled by a runability issue that wasn't so apparent into thinking it's a bad damper or transmission.
What idle rpm is she running at in gear?
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 390 times
Postby Cooler » May 12th, 2020, 10:17 am
Is this sound happening in just reverse, or in both reverse and forward? I have heard a lot of boats with tranny clatter in reverse, and then quiet in forward. It is pretty common actually, especially at low RPM's. The gears in transmissions are not machined on the reverse side the way they are with forward side, and sound like rocks grinding. A boater in our marina had his damper plates replaced, ( $4800 ), thinking they were shot. Result was nothing changed, but the mechanic opined the new noise was normal due to typical reverse gear chatter. That was on a Volvo set up. Good luck! 8-) er
Cooler By The Lake
Users browsing this forum: No registered users and 57 guests
