Hello all and help me out!
emunstar
Vessel Info: 1991 Carver 3207 Aft Cabin
Has thanked: 4 times
Postby emunstar » May 29th, 2020, 2:43 am
Hi all, I'm Edwin from the gulf coast of Texas.
I'm hoping to purchase a 1986 3227 Convertible and am curious if the entire floor at the stern comes off or just the access panels that are clearly removable.
I'm positive I will spend far too many hours in the engine bay to fight with what looks like horrible access.
Thanks in advance for any information you can provide, I hope to be posting pictures of a new to me Carver soon.
Has thanked: 580 times
Been thanked: 1210 times
Re: Hello all and help me out!
Postby bud37 » May 29th, 2020, 6:35 am
Welcome to the forum.....Sorry I don't remember .......perhaps someone with the same model will chime in....good luck with your boat search.
Has thanked: 456 times
Been thanked: 1671 times
Postby Viper » May 29th, 2020, 7:05 am
Welcome aboard Edwin. If I recall correctly, the entire deck's perimeter is fastened with screws visible topsides. Pretty sure it's one piece. I don't think this is something you'd be removing though on a regular basis. It's big and not light, and may also have had some stuff mounted to the underside over the years.
Hope she works out for you. Keep us posted.
throwback2
Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys
Has thanked: 8 times
Been thanked: 22 times
Postby throwback2 » May 29th, 2020, 7:11 am
Viper wrote:Source of the post Welcome aboard Edwin. If I recall correctly, the entire deck's perimeter is fastened with screws visible topsides. Pretty sure it's one piece. I don't think this is something you'd be removing though on a regular basis. It's big and not light, and may also have had some stuff mounted to the underside over the years.
What he said.
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 390 times
Postby Cooler » May 29th, 2020, 11:36 am
Viper is correct. It is very heavy and bulky. And most likely has some stuff at least attached for support purposes. The access looks bad, but it is not as bad as it looks as long as you are really skinny and wiry. I still wish the contortionists from the defunct Barnum & Bailey circus would get trained as marine mechanics. Saw a guy in London jam himself into a 2 cubic foot box. He appears at the park where The Eye is located. He could make a great living at marine repairs. Welcome aboard, and think about a survey before purchase. 8-) er
Cooler By The Lake
emunstar
Postby emunstar » May 29th, 2020, 7:24 pm
Thanks all, you have confirmed my suspicion. I'm about sure the boat will need engine work judging by the 1500 hours on the clock and somewhat neglected condition of the engine bay.
I will definitely get a survey if things progress towards a purchase.
I noticed what looks like erosion of either the prop shaft or the torque tube as well (can't remember which). there was a defined narrowing in the shaft that looked abnormal....... Maybe some fun times ahead.
emunstar
Postby emunstar » May 29th, 2020, 7:39 pm
Cooler wrote:Source of the post Viper is correct. It is very heavy and bulky. And most likely has some stuff at least attached for support purposes. The access looks bad, but it is not as bad as it looks as long as you are really skinny and wiry. I still wish the contortionists from the defunct Barnum & Bailey circus would get trained as marine mechanics. Saw a guy in London jam himself into a 2 cubic foot box. He appears at the park where The Eye is located. He could make a great living at marine repairs. Welcome aboard, and think about a survey before purchase. 8-) er
Not as skinny as I used to be :-D
Been thanked: 615 times
Postby g36 » May 29th, 2020, 7:51 pm
Welcome.
Coastie78
Vessel Info: 1985 32' Carver Model 3227
Postby Coastie78 » June 4th, 2020, 6:01 pm
Hi Edwin, welcome. Unfortunately I have had my deck up at least once a year. As others have said it is screwed into the deck edging all around the edge. To remove take all the screws out, remove the flying bridge ladder, remove the little side storage open compartments (the stbd side has dock water access) make sure your center stainless support is loose under the deck, remove the scupper drains on both sides and finally make sure there is enough play in the trim tab lines that run along the underside of the deck or remove the support screws. Be careful because the center deck support can get a little flimsy. I usually lift mine up from the back and support it with a 4x4. I am going to try to do this lifting up the side closest to the cabin to replace my distributors, or find a very skinny mechanic!
Postby Viper » June 4th, 2020, 9:56 pm
Great info. :down: Welcome aboard
Users browsing this forum: No registered users and 121 guests
