Can anyone tell me which breakers I need to order by brand and number, or are there different brands that would fit. I need a 20 amp for the air conditioner pump and a and 30 amp for the air conditioners , these are AC rocker breakers in the electrical panel , one side red one side black. I know very little about electrical so please dont get to technical.
Thank you
1991 33 Carver aft Cbn AC Rocker breakers
Re: 1991 33 Carver aft Cbn AC Rocker breakers
Should be labeled on the side of the breaker but Carling was a popular brand used by many OEMs. I assume you're referring to a 30 amp main for line #2 which is typically the side dedicated for air conditioning.
- KEND
- Vessel Info: 1991 Carver 33' wide body aft cabin model 3330 twin 330hp Volvo's
- Been thanked: 2 times
Yes, The main for the air, also a 20 amp for the pump. I know the numbers are on the breakers but I have no idea how to get them out. There is groups of 5, side one side two. So I am looking for a part number to try and find replacements.
Maybe someone who's replaced the same ones has kept the part numbers handy or you can contact Carver with your hull number and they should be able to give you the manufacturer and part numbers.
https://www.carlingtech.com/marine
Not 100% sure about your panel, but on most of theses boats there are a few screws around the panel face. Disconnect all shore power, remove the screws and the panel face with breakers and all wiring should pull front. The breaker should have the name and model number on it, or remove it and take it somewhere to match it up.
If you 12v is in the same panel, shut all of your batteries off also before opening the panel.
- KEND
I need a Carling DG1-BO-34-620-131-C, 20 amp and a DG1-BO-34-630-131-C 30 amp breaker. Does anyone have information on where to find either one. I did a search and could only find a 10 amp.
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Just wondering are you sure the breakers are bad?
Unless they overheated and melted they dont often fail.
- KEND
I had a air & heat pro look at my air systems , everything was up to spec, and I told him the water pump breaker kept tripping, then it shut the air units off and the main breaker would trip, he took another 20 amp n a circuit that didn’t pull as many amps and switched it with the water pump 20 amp breaker and it it worked flawlessly since , so I plan to switch out the bad 20 amp breaker with a new one , and a 30 and extra 20 for spares if I can find them.
