Lost Drive Control on Port Side
- GotLuckyPA
- Vessel Info: 1988 Montego 3257
Has anyone dealt with this? Can the seal be replaced while the boat is in the water? Is it a v-drive re-build situation?
Thanks in advance for any help...
- Has thanked: 579 times
- Been thanked: 1210 times
Re: Lost Drive Control on Port Side
- Has thanked: 455 times
- Been thanked: 1671 times
The question is how long did she run dry, hard to tell but it doesn't take long to toast it running at cruising speed with no oil. Too late now but it would have been good to get a sample of oil before they refilled it.
Accessibility is key here. If the area is easy to get to, chances are it can be done in the water. My experience with a lot of v-drive applications though is that it's way easier to work on by pulling out the engine with the tranny. That can be done in the water too but how easy it is to do in your particular marina will determine whether it makes more sense to haul the boat out first. If the unit needs to be removed, you may as well dismantle it and assess whether there is any damage that might come back to haunt you.
- GotLuckyPA
bud37 wrote:Source of the post Is there half a chance it was just the dipstick loose ?
I don't think so.
- GotLuckyPA
Viper wrote:Source of the post Welcome to the forum.
Understood. I'll keep digging and let you know.
- GotLuckyPA
Users browsing this forum: No registered users and 54 guests
