Hello All,
My toilet all of a sudden is letting fresh clean water into the bowl when not in use. Within about an hour the bowl over flows. I have had to turn off the water to the boat but need to turn it back on for general use but can't due to the problem. I have a fresh water electric head. Not sure but think it is a Jabsco.
Any help is appreciated.
Thanks...
Carver 2005 33 SS Toilet Lets Fresh Clean Water Into Bowl When Not In Use
Re: Carver 2005 33 SS Toilet Lets Fresh Clean Water Into Bowl When Not In Use
You have a solenoid valve that controls the waterflow into the toilet. Sounds like either there is something in the seat not letting it close or the diaphragm needs replaced.
- TurboWarp
- Vessel Info: 2005 Carver 33 Super Sport
- Has thanked: 1 time
Thanks! Any idea on the location of the solenoid for this model?
it should be near the toilet. Mine is behind the wall behind the toilet. You can see the mounting screws from inside the bathroom.
