V drive light on
- Tbone17
- Vessel Info: 1984 carver crusader 220 engines 305 cubic inches
V drive light on
I was wondering why my v drive light was on on my 1984 carver with 220 crusaders even though I checked the oil which it said to do in the Manuel but the oil was full is there any other reasons why the light would be on.
- Been thanked: 1312 times
Re: V drive light on
When is the light on ?.....if I remember right I believe the light goes out above 11 or 1200 rpm, something like that.
What does your operating manual say ?
Bud is correct. They will stay on until about 1200 rpm in gear typically. Then they should turn off. If they don't, then you need to find out why, first step is to check the oil.
- Tbone17
- Tbone17
- Been thanked: 492 times
The light is on because you either have a bad pressure switch or you don't have enough oil pressure.
- Tbone17
Tbone17, does it stay on after 1200 rpm in gear while underway or are you checking that in neutral at the dock? It must be over 1200 IN gear.
- Firstclass
- Has thanked: 4 times
Hey there,
Is there a difference between the v-drive light staying on or blinking? Mine is blinking continuously while driving above 1200 rpm
