fly bridge helm steering
Topic author
detroitdingman
Vessel Info: 1985 voyager
Postby detroitdingman » May 27th, 2015, 1:31 pm
Hello every one . new here
i have me a 1985 carver voyager my fly bridge helm dos nothing no steering , where do i check the hydraulic fluid on this boat . bottom steering works fine.. the top just spins almost freely . any advice will be appreciated.... :worthy:
Has thanked: 53 times
Been thanked: 426 times
Re: fly bridge helm steering
Postby waybomb » May 27th, 2015, 9:07 pm
I am guessing a Hynautic system? Air floats to the top
You need to locate the reservoir. Could be back by the rudders. If it is low on fluid, you have a leak somewhere that needs to be fixed.. If you have no air pressure, you'll need to charge it to about 25psi along with filling fluid, to find the leak.
If you have air pressure and you have fluid, the way to clear air from a hynautic system is to turn the wheel in one direction for many turns, like 75-100. Then the other way. If that doesn't clear the air, you may have to loosen one fitting at a time behind the wheel and bleed that air out. Be careful, those fittings are expensive, since this system is no longer made. Start with the center one, then either side port.
If you don't have a hynautic system, disregard what I wrote.
To identify it, go to ebay and search Hynautic h50. This is how your helm pump looks. Your steering wheel attaches right to it.
I believe if you search Hynautic, you'll find the webpage with some manuals on the system. One of them describes
the air bleeding process as above.
ps - from your user ID, you in Detroit? During the week I'm downriver in Trenton.
Topic author
detroitdingman
Postby detroitdingman » May 28th, 2015, 2:18 pm
thank you waybomb for the info ,, it is hydraulic , if i have a leak some where wont that make the bottom helm not working either ? im going to locate the pump hopefully today . im going tear that boat up lol , im in detroit area i dock in erie , again thank you , if you know of any one that can help me with this please let know.
Postby waybomb » May 28th, 2015, 3:29 pm
The brand is hynautic.
The pump is what the steering wheel is mounted on.
Dual station means dual pumps. You turn the wheel and that moves the fluid.
The reservoir holds the fluid. The 25psi air charge is what pushes the fluid out to the helm pumps. The helm pumps move the fluid to either side of the steering cylinder that is connected to the rudder tie bar.
It is a completely mechanical system.
Topic author
detroitdingman
Postby detroitdingman » May 28th, 2015, 10:18 pm
I went Down to marina today hoping I can do something with it , well after 3 beers I looked at the floor ,I'm telling my self that's where the reservoir should be .i looked for anything like acces with out tearing carpet up nothing ,I walked back out and finished the other 3' .. I'm just going to set on the bridge and turn the wheel for few hours ,that should fix it ,, lol thank you ,
Users browsing this forum: No registered users and 107 guests
