MANY projects finished up
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
BIUSY weekend! I had a few lose ends to finish up, I replaced the fresh water pump with a new Johnson, no more surge. I also got the EDECOA 2500W/5000W inverter installed. Since it was a bit wider that the one I had, I had to move it to the other side of the salon stairs. It is hooked to the house bank, with a 150A breaker. I tried it, and I will say, with the 1100W Coffeemaker it went from 100% to 91% in the time it took to brew. I am looking for a smaller coffeemaker for when we are on the hook. I also got rid of the original sound system, you know, AM/FM, Cassette, CD player. Replaced it with a BOSS 240W gauge style unit with Bluetooth. All that is left is to install the redbud kit for the forward Vacuflush head.
- rjr
- Vessel Info: 440 MY
- Has thanked: 25 times
- Been thanked: 9 times
Re: MANY projects finished up
everything looks good. Can you caption or describe the pics?? What is a redbud kit?
- tonyiiiafl
tonyiiiafl wrote:Qr Bbpost BIUSY weekend! I had a few lose ends to finish up, I replaced the fresh water pump with a new Johnson, no more surge. I also got the EDECOA 2500W/5000W inverter installed. Since it was a bit wider that the one I had, I had to move it to the other side of the salon stairs. It is hooked to the house bank, with a 150A breaker. I tried it, and I will say, with the 1100W Coffeemaker it went from 100% to 91% in the time it took to brew. I am looking for a smaller coffeemaker for when we are on the hook. I also got rid of the original sound system, you know, AM/FM, Cassette, CD player. Replaced it with a BOSS 240W gauge style unit with Bluetooth. All that is left is to install the rebuild kit for the forward Vacuflush head.
