Volvo 8.1 Missing/Surging
- Has thanked: 456 times
- Been thanked: 1671 times
Re: Volvo 8.1 Missing/Surging
- Been thanked: 1043 times
If you're seeing a quick fluctuation in the tach, that indicates it's not a secondary ignition or a fuel starvation issue, but surging could definitely be fuel starvation (and usually is). If you mean the tach is slowly moving up and down with engine RPMs it's a "following" symptom but if there is quick movement it's a "causation" symptom, meaning whatever is causing the quick movement is likely causing the engine RPMs to fluctuate and that it's related to the primary side of the ignition or what's triggering the primary side (things like a crank sensor or ECM).
- Cooler
- Has thanked: 68 times
- Been thanked: 390 times
- Cliffm
"the Condo"
- Has thanked: 260 times
- Been thanked: 19 times
tjh408 wrote:Source of the post I will look when performing my engine room yoga Friday, I didn't see one when I looked last week.
on our 2006 -Volvo 8.1 TBI, the fuel filters are located on the motor, above the bell-housing area.
- tjh408
- Vessel Info: 2003 Carver 360 Sport Sedan
- Has thanked: 18 times
- Been thanked: 9 times
Marina tech finally arrived on Thursday (13 days) he found no code issues, and fuel pressures to be in normal ranges. Sorry I don't have the values he found. I did pull the fuel line and remove the check valve from the tank, it was clear and clean. So now I am waiting for a call back from the next Marina tech at an adjacent yard to see when they can look at it. Short season in New England!
- Has thanked: 580 times
- Been thanked: 1210 times
- tjh408
- Cooler
- tjh408
Users browsing this forum: No registered users and 145 guests
