Location of sea strainer
LJ0629!
Vessel Info: 1989 Carver 3807 AFT Cabin
Has thanked: 2 times
Post by LJ0629! »
Hey all I am new to this forum and owner of a new to us 1989 3807 AFT Cabin. We are not new boaters/cruiser’s but new to this vessel. The AFT AC works great however the front is not working, it blows but no cooling, I am thinking the pump or maybe a clogged strainer where might I locate the items. We purchased this boat knowing there were a couple of issues mostly just cleaning and sprucing up engines and gen in good shape. Thanks for you help in advance and safe boating to all!
Re: Location of sea strainer
Welcome aboard
The pump and strainer are in front of the starboard engine. There is only one raw water pump for all the units on board unless someone changed something. If the aft unit is working, the pump should be fine. Have you tried checking to see if the fwd unit works on the heat cycle? Also make sure the evaporator and intake screen are clean and free from obstructions, and check to ensure water is discharging on the starboard side at the bow close to the water line if you're talking about the v-berth unit.
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Post by buster53 »
What viper said...
I used to have a 3807 and it had 3 AC units all running on one pump. When you are running both units, do you have water discharge of both units?
Dumb question...have you turned down the temperature low enough to kick in the compressor? Can you hear the compressor turning on and off as you adjust the temp either up or down?
Agree with viper, turn it on heat mode and see what happens.
Several things could be happening and unfortunately, one issue could be a bad AC that needs to be replaced.
Play around with it and let us know what's happening.
How many units are you running at the same time and are you hooked up to a 50 amp shore power service or just 30 amps on each side? Are your AC units the old originals with 3 control knobs each or have they been upgraded?
