water in bow
- RWS
- Vessel Info: 1987 3607 aft
- Has thanked: 28 times
water in bow
Thank you for your help ,
RWS
- Has thanked: 458 times
- Been thanked: 1698 times
Re: water in bow
When you’re on board, and you are using your on board water from your tank, do you hear your water pump click on for a second even though you’re not running any water? If it kicks in periodically, you likely have a system leak or bad check valve.
When you vacuum out ALL the water, how long does it take to get to that level? Have you had rainy days? Does it happen with the water system shut off while you’re away on week days or only when you’re aboard? Take measures to narrow down when it’s happening. To do that, vacuum it all out first then go from there. I would do that last before you leave for the week and check as soon as you get back before you turn on the water system.
- Been thanked: 622 times
Re: water in bow
- bobcinga
- Vessel Info: 2006 CMY 41
- Been thanked: 4 times
Re: water in bow
- RWS
Re: water in bow
- Has thanked: 72 times
- Been thanked: 1055 times
Re: water in bow
Could you have the shower sump overflowing?
On my 3607, the rode locker under the fwd berth drains into the bilge. Does yours really have an overboard drain? It could also drain into the shower sump (which is probably the perferred method), but on mine it goes directly to that forward bilge.
- RWS
Re: water in bow
- chpsk8
- Has thanked: 27 times
- Been thanked: 75 times
Re: water in bow
Are you sure the shower bilge pump is working?
One thing to check is the hose between the water tank and the pump. If that has a defect it won’t kick the water pump on, but will still leak.
I’m assuming you have an aft, mid and forward bilge pump. Have you found any water in the mid bilge? That water would move to the forward bilge under the right circumstances.
- RWS
Re: water in bow
- Cooler
- Has thanked: 68 times
- Been thanked: 400 times
Re: water in bow
Users browsing this forum: Google [Bot] and 16 guests
