Trumpet horns stopped working today
Helmsman
Has thanked: 73 times
Been thanked: 42 times
Re: Trumpet horns stopped working today
Post by Helmsman »
You mentioned fog. Mine went bad after I washed the boat one day. I had read that spraying a little WD40 would cause the horn to blow. It did. The horn failed the next time it rained. I replaced the horn and it works fine now. They are evidently more sensitive to water as they age.
Cliffm wrote:Qr Bbpost So.... Plot thickens! Pulled under dash panel to access backside of horn mount wiring, looked good, so I removed dash panel to access horn rocker switch which turned out to be a relay switch. so I tried it and horn blew?
So, the $100 question. Is my "old" Marcinco AFI trumpet horns being temperamental/going bad... or is the horn "relay" rocker switch going bad when used "allott"?
Any EE's having insight to my dilemma?
One thing is for sure, it is satisfying taking care of your hooters......... :-D
Cliffm
Vessel Info: 2006 Carver 36 MY
"the Condo"
VP 8.1Gi-F
Has thanked: 260 times
Been thanked: 21 times
Post by Cliffm »
Nharrison5 wrote:Qr Bbpost You mentioned fog. Mine went bad after I washed the boat one day. I had read that spraying a little WD40 would cause the horn to blow. It did. The horn failed the next time it rained. I replaced the horn and it works fine now. They are evidently more sensitive to water as they age.
Thanks, thinking that after finding our helm stereo speakers having severely deteriorated cones, and replacing them this weekend.
Cliffm
"the Condo"
VP 8.1Gi-F
Post by Cliffm »
They died!
went to WestMarine, bought the Marinko 12V 123db pair, swapped out, sounds great!
appear to be the same make as previous OEM installed units, hoping they last as long.
