3607 decking template?
- phatboat
- Vessel Info: 1985 3607
Does anybody have a template for 3607 deck? I want to put some synthetic decking on mine and I would love to find a template. Has anyone put decking on their 3607?
Re: 3607 decking template?
It's best if you template it yourself in case a previous owner has added or changed something that would make a template from another 3607 useless. It's not really that difficult to make one. Personally I prefer using a rolled flexible clear plastic product that's thick enough to keep its shape when you lay it down. Using a clear product let's you see any hardware you roll over so you can trace around it. Use a system of numbers or letters to mark adjoining edges of different sheets, and mark alignment lines going through both adjoining sheets to ensure they are aligned properly on your material. Do a search on line, there's some pretty good videos.
What are you laying down?
- chpsk8
- Has thanked: 27 times
- Been thanked: 76 times
Go to sailrite and look up durascrim. Then look at the project center for how to make a template. Super easy and makes sure it fits your boat perfectly.
