Gen water leak maybe?
- RWS
- Vessel Info: 1987 3607 aft
- Has thanked: 28 times
So I fired the gen up and couldn't see a leak. could it be condensation or a small leak I just can't see. Viper what are your thoughts sir? Thank you everyone for ideas.
- Been thanked: 615 times
Re: Gen water leak maybe?
- Has thanked: 456 times
- Been thanked: 1671 times
What brand and model generator do you have? Is it an Onan MCCK, and is it fresh water or raw water cooled?
- RWS
- RWS
- RWS
Viper wrote:it is fresh water cooled Onan. Had an impeller go bad this year, wondering if it the housing is not sealed well or a line is a little loose. It ran well, just like it always has.
Viper wrote:I remember the location of the genny in the 3607 but don't recall if there are any fresh water system lines running above it against the bulkhead. Turn on your fresh water pump and check for leaks above the genny. If your pump cycles with all the faucets off, then there's a leak somewhere or a faulty check valve in the pump. For your vintage, you probably have the grey Qest lines and fittings. Check the fittings for leaks.
I went to the boat today, started and loaded the genny and let it run about an hour and no apparent leaks. Also checked for a fresh water leak. Nothing found and water level in catch pan did not increase nor in the hull. Is it possible for water to have remained there for several months from when Dale changed the impeller in mid July?
- Has thanked: 580 times
- Been thanked: 1210 times
Users browsing this forum: No registered users and 109 guests
