Fuel tanks
Steve2020
Vessel Info: 2006 41 CMY
Has thanked: 21 times
Been thanked: 4 times
Fuel tanks
Post by Steve2020 »
New owner of a 2006 CMY 41 I am wondering on a cruise with all four tanks full which ones are best to use first. It has two rear 50 gal. And two midship 130 gal thanks for any tips.
Re: Fuel tanks
Post by Midnightsun »
I prefer to use up the AUX (rear) tanks first to get the weight out of the ass of the boat. Not sure it really makes a difference. Make sure you do go through main and aux tanks to freshen up fuel during the season. Nice boat you have there by the way. :-D
Been thanked: 492 times
Re: Fuel tanks
Post by waybomb »
Welcome aboard!
Re: Fuel tanks
Post by g36 »
I also have 4 in my 405 and I also use up the aft tanks first, just what I've always done and also welcome
Hugo
Has thanked: 2 times
Been thanked: 23 times
Re: Fuel tanks
Post by Hugo »
Carver will tell you to use the main tanks first. Reason being that you can control bow angle down with the trim tabs but if you remove the weight from the stern you can't put the bow up if needed like a following sea or an inlet. However, if you have a heavy tender on the stern it may make sense to drain aux tanks first.
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Re: Fuel tanks
Post by Tireless »
When I am on a big crossing I always burn the aux tanks first. When on plane, fuel in the aux adds too much weight and causes the aft to drag, therefore impacting your speed. If I am not going too far, I prefer to keep the fuel in the aux's at a minimum. This is what works best in my 44 CMY.
Greg
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: Fuel tanks
Post by buster53 »
I also prefer using the aft first. When taking a trip, I use aft to get to my destination and main to get back home. Good way to insure you are using your tanks equally.
Re: Fuel tanks
Post by tomschauer »
I also always burn the aft fuel first.
