Volvo Penta 8.1l Gi-F light load miss fix
- Cliffm
"the Condo"
- Has thanked: 260 times
- Been thanked: 19 times
It would run smooth for a bit, then rough, then smooth. I initially thought we'd sucked up some residual water in the fuel tank, and has it trapped in the filter from our most recent fillup.
After we came back, I decided to pull spark plugs to get a read on their condition. Turns out they were OEM from 2006, with 270hrs, and one has cracked insulator. A quick trip to auto parts store got me a new set of exact replacements.
Now a much smoother running motor!
- tjh408
- Vessel Info: 2003 Carver 360 Sport Sedan
- Has thanked: 18 times
- Been thanked: 9 times
Re: Volvo Penta 8.1l Gi-F light load miss fix
- Cooler
- Has thanked: 68 times
- Been thanked: 390 times
- Cliffm
"the Condo"
Cooler wrote:Source of the post 14 years on the same set of plugs?!!!! WOW. That cracked one could have been real trouble. Did you get all the porcelain pieces out? Hope you did get marine plugs. They will not rust like standard automotive plugs will. er
41-983 AC Delco platinum plugs where installed OEM by Volvo Penta. These were readily available at O'Reilly autoparts. Since they went 14yrs, I'm hoping the replacements go another +7yrs. No rust on the OEM plugs.
- pepmyster
8.1 Volvo Penta
- Has thanked: 474 times
- Been thanked: 201 times
- Cliffm
"the Condo"
pepmyster wrote:Source of the post Happened to me but no sputter. 2004 360ss, 650hours. I just bought the boat and wanted to do a complete plug change. PO said they were replaced by the other PO. Original plugs on the boat! Right from the factory with the red paint. Go figure.
I know right! Two PO's and no change, plus we paid for motor inspection, who said they pulled the plugs, but no mention of the cracked one...that had grease in it!I
In thinking I should have bumped up one heat range,as they were carboned up a bit. We'll see.
- pepmyster
8.1 Volvo Penta
- Has thanked: 324 times
- Been thanked: 595 times
- Has thanked: 580 times
- Been thanked: 1210 times
Cliffm wrote:Source of the postpepmyster wrote:Source of the post Happened to me but no sputter. 2004 360ss, 650hours. I just bought the boat and wanted to do a complete plug change. PO said they were replaced by the other PO. Original plugs on the boat! Right from the factory with the red paint. Go figure.
Perhaps they cracked the plug during the inspection.....heh who knows now right.
- pepmyster
8.1 Volvo Penta
