Circuit Breakers
Gary Rose
Vessel Info: 2000 356 carver aft
Has thanked: 5 times
Been thanked: 3 times
Circuit Breakers
Post by Gary Rose »
I have a 2000 356 and I am looking where to get the main 110v breaker for my boat. It is a 3 pole breaker but only has one switch. Tried West Marine but no help. Any Ideas ???????????
Re: Circuit Breakers
Post by Midnightsun »
Try searching on Blue Sea site, probably supplied/made by them. https://www.bluesea.com/
Been thanked: 1114 times
They are out there. What style is yours... a rocker or a handle?
Here's one example, but it could be a Blue Seas or a Carling:
https://www.iboats.com/shop/paneltronic ... -coil.html
Gary Rose
Post by Gary Rose »
It is a carling its a single handle part Number is ab3-x0-00-065-3d1-c. Carver part # is 8900333
Gary Rose
Post by Gary Rose »
There should be an id sticker on there ....if so just get the info from it and match up......you can get them on Amazon as well.....probably Carling unless it has been replaced before you.
Fyi any switch you consider....just double check the spacing for the mounting screws...
chpsk8
Has thanked: 27 times
Been thanked: 76 times
Post by chpsk8 »
Try Great Lakes skipper .com or fpmarine.com. Both have a lot of choices for breakers.
vineyardgray
Has thanked: 128 times
Been thanked: 33 times
Post by vineyardgray »
I had a similar three pole, single switch breaker and was told that they don't make them with internal links any more - I had to get one with two switches with an external "joining bar" (there is a name for this link but i'm drawing a blank)
It still fit in the same spot - just needed to drill another hole.
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
