Quick question, I have no idea what type oil has been used in my engines over the years. I have about 80 hours on the oil and neither engine has used a drop since I got the boat about 2 1/2 years ago. Current hours are 472 and 477.
I would like to change the oil before this spring and ya know the 7.4 MPI Mercs better than anyone.
Is it safe to use Mobil One Synthetic and call me old school, maybe even overkill, but I also like to add a small bottle of Slick 50 Synthetic which I have used since 1989.
Is there another oil I should be using instead?
I would imagine the transmission fluid is changed at the same time?
What guidelines do ya normally go by?
Thanks in advance and I sent up some more
money. I hope ya are having an awesome weekend.
Says right on the jug "European Formula" plus it says meets Mercedes XXXX certification which is the one required for my vehicle.
Also -I have found that synth in older vehicles - which is what I often drive to the scrap yard - slips out more easily and seems to burn off faster than dino. Considering the relatively low hours I anticipate experiencing on the boat, I will stick to dino.
