Upper helm floor access
- Roddono
- Vessel Info: 1991 Carver 33 Aft Cabin
- Has thanked: 26 times
Ray
- Has thanked: 455 times
- Been thanked: 1671 times
Re: Upper helm floor access
- Roddono
Viper wrote:Source of the post Have you tried using an electrical wire fish? Or, if you see any cut wires under the helm that aren't being used anymore and are heading in the direction you want, you can use them to tape the new wire to then pull the old wire to bring the new one to the same area. I've cleaned up a lot of my wiring from the upper helm and used that method a lot. When you run something through there, attach some good quality twine and run it with the new wire. Leave enough at both ends so that you can attach future wiring to it next time you want to run through there. I use the strapping used for shrink wrapping, works great. I have some going from my engine compartment up to the flybridge bench, from the bench to the helm, and from the bench through the radar arch. Makes future installs way easier.
Great idea. I will do that.
Thanks.
Ray...
- V12diablo
- Vessel Info: 2001 Carver 356 Aft Cabin
- Has thanked: 1 time
- Been thanked: 13 times
Jason
- Been thanked: 615 times
- Roddono
V12diablo wrote:Source of the post I just disassembled my fly bridge on my 356 for transport and it had a similar setup. I had to take out the side panel of the fly bridge (shown in the bottom of your first pic). That allowed me to remove the access panel to the wires and gain access to the run going down into the salon. There was a screw in the front and back of the side panel and then you should be able to pull it out.
Jason
Awesome.
Thank you
- chpsk8
- Has thanked: 27 times
- Been thanked: 75 times
Users browsing this forum: No registered users and 138 guests
