Ignition Switch
- Wsullivan71
- Vessel Info: 2001 Carver 404 Motor Yacht
- Been thanked: 11 times
Ignition Switch
- Has thanked: 268 times
- Been thanked: 1153 times
Re: Ignition Switch
- Been thanked: 1043 times
Re: Ignition Switch
And this happens on BOTH engines at the same time or just ONE engine does this or EITHER engine will do this at various different times?
- Has thanked: 579 times
- Been thanked: 1210 times
Re: Ignition Switch
- chpsk8
- Has thanked: 27 times
- Been thanked: 75 times
Re: Ignition Switch
That connector had corroded and would only work intermittently. Bypassed the connector with a splice and I've never had a problem since. (knocks wood).
If it's both motors you'll be looking for something shared such as a ground or power line. Connections are always a good first check. Remove, clean and reinstall ground connections is never a bad idea.
- Wsullivan71
Re: Ignition Switch
Thanks Bud37, the starter relays would be an easy fix. Any idea where they are located?
I'll also check the 12V positive feed to the helm station. Thanks Hans.
Re: Ignition Switch
- Dewmyster
- Vessel Info: 1998 370 Voyager
- Been thanked: 12 times
Re: Ignition Switch
- Has thanked: 455 times
- Been thanked: 1671 times
Re: Ignition Switch
- Wsullivan71
Re: Ignition Switch
Users browsing this forum: mparks813 and 14 guests
