1998 350 Mariner Mercruise 350 Magnum 2800 RPM WOT issue
Been thanked: 1114 times
Re: 1998 350 Mariner Mercruise 350 Magnum 2800 RPM WOT issue
grizer wrote:Qr Bbpost All new fuel filters, replaced fuel pumps, stil 20-25 psi at fuel rail and still limited to about 2600-2800 rpm. No change. Merc suggested fuel regulator test by pulling vac hose at intake but that produced no different results. Really baffling and my mechanic just through up his hands.
You keep saying the fuel filters were changed, but I haven't seen you confirm the presence or absence of one in the Cool Fuel module which some have suggested checking. I have read some other posts where folks have had issues with that filter in the module and others that have confirmed there is no filter...so either it was removed in their cases or there are some situations where the Cool Fuel module comes equipped with one and others where it doesn't.
I'll check again but I don't think the serial number you provided came up. Can you confirm the engine serial number.
tbachelor
Vessel Info: 2000 Carver 350 Mariner
Post by tbachelor »
I know this is an old post but was your problem ever resolved? I have the same issue with one of my port engine. 2000 Carver 350 Mariner with 350 MAG MPI's. Boat is new to me last year and trying to figure out why my port engine wont go past 3000rpms. Thanks for any help
JohnS
Vessel Info: 2003 350 Mariner
Has thanked: 39 times
Been thanked: 16 times
Post by JohnS »
Any resolve?
The OP hasn't been active here since mid March, he may not be around anymore. It may be best to start your own thread with the symptoms you're experiencing. Give us engine info and as much info about the symptoms and conditions as possible.
rrhahn
Vessel Info: 2001 350 mariner CDR-R8082C101 Carver Mod.#3597 Port Engine # OL675853, It seems both engines are in limp mode, with max rpm's at 3000rpms, at start I get two beeps at both engines, but they start immediately, checked fuel psi and all other sensors, also hired two mercury mechs. can't find a answer, any ideas ?
Post by rrhahn »
HAVE U LOOKED AT THE GROUND WIRES ?
