Hello need some input on my 1981 carver steering cable changeover
Stacey2377
Vessel Info: 1981 Carver Mariner 3396
Post by Stacey2377 »
Hello All!!
I am new to the forum and I have a 1981 Carver Mariner 33ft. I have had the boat two years and when I purchased I was told the steering cable was bad. No biggie, right? Wrong! My cable is obsolete and I talked to the manufacturer and have a replacement part but I have some questions about how it’s attaching to the rudders because the two cable have differences... any input would be much appreciated. Has anyone had to replace theirs?
Been thanked: 492 times
Re: Hello need some input on my 1981 carver steering cable changeover
Post by waybomb »
Can't help with this issue, but welcome aboard!
Post by g36 »
Welcome. Can you post some pictures of the cables and fittings at the rudders might help get assistance.
Been thanked: 470 times
Post by RGrew176 »
Lots of really sharp people here. Someone will be able to assist you. Good luck.
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 414 times
Post by Cooler »
This is something I would have a good marine mechanic look at. Steering cables can be tricky, and if installed just a little off, can be the source of perpetual troubles. Really sucks when you are 25 miles from port and completely lose steering capability. I did learn something though. Thought all Mariners had hydraulic steering, but apparently not. Good luck. Here is some info on your steering system. Go to section D 8-) er
https://carveryachts.blob.core.windows. ... ver_81.pdf
Cooler By The Lake
Lenard
Vessel Info: 1981 Carver 3396,
Post by Lenard »
I have the same boat. My cable is seized and I am looking for a replacement. Could you be so kind as to forward the replacement cable number and manufacturer.
