Hi
I have 1999 350 Mariner. Will be replacing both port starboard dripless and coupling seal with Tides. Does anyone know approximately with labor what this would cost? just so I have ballpark idea when I get quotes from yard. I am overseas so that will certainly impact, but at least I will have some comparison.
Don
Prop Shaft Coupling Removal
Re: Prop Shaft Coupling Removal
It's really going to depend on access Don. If it's a v-drive mounted on the engine, that configuration tends to be much more difficult to access, a real pain actually. The labour will be dependent this, other than that, it's parts, shipping, misc. supplies, and the door rate in your area.
