Master Breaker Panel 1997 Carver 405
Wayne162
"Change In Latitude"
Has thanked: 16 times
Been thanked: 32 times
Post by Wayne162 »
I am unable to get shore power to the right half of my main panel controlling the AC and AC pump. The left side for everything else shows 120 and is all good. When on ship power, everything works fine on generator. This problem just started last week. The marina noted that the power on the dock is fine. I have checked the breaker in the main box and found the right side tripped. The breaker at the stern was checked and appeared on. It was reset but nothing happened. Any ideas? :usa:
Been thanked: 492 times
Re: Master Breaker Panel 1997 Carver 405
Post by waybomb »
Check the cord - try a different one.
Next I'd pull the connector out of the bulkhead and check the connections on the back side.
Wayne162
Post by Wayne162 »
Thanks, will do and let you know.
Wayne162
Post by Wayne162 »
Slow in my follow-up but the problem was in the marina wiring. Moved to my new slip and power was fine on my end.
Post by waybomb »
Glad you've been energized...
