SOLAR PANEL INSTALLATION
tonyiiiafl
Has thanked: 601 times
Been thanked: 190 times
Re: SOLAR PANEL INSTALLATION
Postby tonyiiiafl » June 6th, 2021, 6:52 am
Those are the same as I have. Once you check out photo 2, same situation, Marked POS POS in, and NEG NEG out. Don’t quite understand that. However, I am running 4 panels,, 2 each hooked in series, then joining the 2 in series in a parallel manner, so these will work, just confusing as all Hell!
tonyiiiafl
Postby tonyiiiafl » June 6th, 2021, 8:08 am
Also, here is the installation better than 1/2 done. I am surprised, but those panels are SOLID! Full cure in another 12 hours, but they do not budge! I have a cubby on my 390 behind the couch where the central vac is, I am going to tuck the MPPT charge controller in there. I am also going to place a disconnect switch before and after the controller. Over kill for 2?
Has thanked: 268 times
Been thanked: 1153 times
Postby Midnightsun » June 6th, 2021, 9:52 am
That stands for "piece of $hit" and "no effen good". Got to buy some of the good stuff. :-D
tonyiiiafl
Postby tonyiiiafl » June 6th, 2021, 11:51 am
You made me laugh !
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Postby Tireless » June 8th, 2021, 10:36 am
Your panels mounted with 4200 are going no where. My friend had to move 4 elevator bolts this week end to install a new panel. He had a hard time getting the mounts off to move them. Mine are mounted the same way and I have had no issues.
The install looks great.
Greg
tonyiiiafl
Postby tonyiiiafl » June 8th, 2021, 12:46 pm
Thank you, I hope to finish up this weekend, final photos to come.
Been thanked: 615 times
Postby g36 » June 8th, 2021, 3:47 pm
Thanks for keeping the updates and pics coming
Has thanked: 455 times
Been thanked: 1671 times
Postby Viper » June 8th, 2021, 9:08 pm
Great job Tony, can't wait to get some real life operating numbers from you.
tonyiiiafl
Postby tonyiiiafl » June 13th, 2021, 8:28 pm
Put it on line today. Very impressed. I shut shore power, and ran from batteries. ALL day, fridge was working, toilet and water pressure pump, inverter for coffee. Batteries stayed at 100%. Controller, went up, down, and kept up with the load. Next weekend a weekend away on the hook.
Has thanked: 579 times
Been thanked: 1210 times
Postby bud37 » June 13th, 2021, 8:39 pm
You da man......nice...have fun with your new boat...and thanks for posting your progress as this will help others down the road I am sure..... :down:
Return to “Electrical”
Users browsing this forum: No registered users and 42 guests
