thru hull fittings
- gatehopper
- Vessel Info: 1986 Carver Mariner 32
home port Orient Heights Yacht Club
Boston Ma. - Location: Boston Ma
- Been thanked: 2 times
- Contact:
thru hull fittings
Thanks Gatehopper
- Has thanked: 53 times
- Been thanked: 426 times
Re: thru hull fittings
The hardest part is getting to the backside of some them, but they were all accessible.
It is not difficult work.
But it scratch-up-your-arms work! A few choice words come out of nowhere as well.
- gatehopper
- Contact:
Also, I set the fittings in the hole, then taped around the fitting. Pulled the fitting out, and taped the visible part. The applied 5200 to the backside of the flange.Tightened the nut up, and simply wiped the oozed-out 5200 from the tape and removed the tape. No clean up of 5200 from the hull this way, or the fitting.
Users browsing this forum: No registered users and 54 guests
