Ignition Switch
Re: Ignition Switch
Wsullivan71 wrote:Qr Bbpost Thanks everyone, appreciate all of your tips! I will let you know what I find once I get back to the boat next month.
That will be great to hear what you found...thanks...
Wsullivan71
Vessel Info: 2001 Carver 404 Motor Yacht
Been thanked: 12 times
Re: Ignition Switch
Post by Wsullivan71 »
Update on my starting problem....Viper was 100% correct. Both starter solenoids were bad. I changed them out and both engines started right up! $37 part so worth carrying a spare.
Re: Ignition Switch
Thanks for the update. Yep, that's the slave solenoid, pretty common failure. This will help others experiencing the same fault later. :down:
Dewmyster
Vessel Info: 1998 370 Voyager
Re: Ignition Switch
Post by Dewmyster »
My problem was finally resolved when I followed Viper's instruction on replacing the slave solenoid. Thank you Viper :down:
:usa:
Re: Ignition Switch
:down:
