Riviera bilge question
- Has thanked: 579 times
- Been thanked: 1210 times
Re: Riviera bilge question
- SunsetSteve
- Vessel Info: 83 Carver Riviera 28
76 Albin 25 (outgoing) - Location: Gananoque
- Has thanked: 30 times
- Been thanked: 19 times
- Petemait
- Vessel Info: 1983 Carver Riviera
- Has thanked: 56 times
- Been thanked: 18 times
Good luck finding the leak. I have fixed water hose leaks with 1/2" pex which is also easier than it sounds.
Best,
1983 Riviera 2807
Boston, MA
- SunsetSteve
- Petemait
This is just above the water line so it may be difficult to do in the water if there is no existing thru hull.
1983 Riviera 2807
Boston, MA
- Uncle Mike
- Vessel Info: Carver Riviera 2807 1986
- Has thanked: 38 times
- Been thanked: 5 times
I haven't check for the fwd pump but the master one (mid bilge pump) is connected directly to the battery, no switch or breaker is needed.
I was lucky to get all the original documents and technical sheets (wiring plan, etc...) with my new to me Carver Riviera 1989, let me know if I can provide you information;)
- Been thanked: 1043 times
SunsetSteve wrote:Source of the post I am not concerned about installing a pump and float switch. The difficult bit to my mind (other than getting wires somehow into the bilge from the panel or more accurately, from the battery) is to hook up a hose and lead it to a through-hull that spills it overboard. None of the Youtube videos so far address that phase.
The trickiest part is knowing exactly where you want to drill, so that you don't drill into anything. This is a "measure more times than you think would be every practical, and THEN measure again before you drill" exercise. If the thru-hull is going to be on the forward half of the hull, you need to make sure it is well clear of any bow wave you create moving forward so you don't risk allowing water into the boat. Most pumps are rated for a three foot lift so you can be well above the water line but you don't want to go TOO high because you'll just lose pumping capability. Once you find the right spot, the actual installation is pretty straight-forward... you just drill the right size, caulk the fitting and install from the outside and tighten on the inside and connect the hose.
- SunsetSteve
If you haven't already, I would go all the way around the hull on the outside and identify any thru-hulls, and then match those to their usage. I had one that combined the galley sink and the fwd shower sump before it exited at one thru-hull.
