7.4 mercruiser winterizing
- crquisto
- Vessel Info: 2000 Carver 406 Aft Cabin, twin 7.4 gas Mercruisers - Flyboy II
- Has thanked: 2 times
- Been thanked: 3 times
Does anyone know how many gallons of antifreeze it takes to winterize each engine's seawater side from the thru-hull to the exhaust on my 2000 405 with 7.4 Mercruisers?
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
Re: 7.4 mercruiser winterizing
crquisto wrote:Does anyone know how many gallons of antifreeze it takes to winterize each engine's seawater side from the thru-hull to the exhaust on my 2000 405 with 7.4 Mercruisers?
If I understand this correctly you keep feeding it until the antifreeze comes out the exhaust. My 350 MPI's take around 4 gallons before the pink comes out. It will be more if one of your engines routes water to your water heater while underway.
Former 2001 350 Mariner owner
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Yep, once the pink is pumping out of your exhaust - mission accomplished.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
- crquisto
My 2000 406 book says to fill a 5 gallon bucket with antifreeze and run it all through. Si cs you can't see the exhaust color with the boat in the water, that's what I do and have had no problems
