454xli throttle body injection fuel pump
honkydog
Vessel Info: 1995 370 Voyager
Been thanked: 2 times
Post by honkydog »
I had a no start issue on one of my 95 454xli engines. I traced voltage down to the fuel pump, but it just wasn't cycling when key moved to ON position. Sharing this as I was not able to locate much information online regarding sourcing a replacement pump.
I ordered two fuel pumps since I could not find anyone selling the original pump. I needed to be certain I would have a solution when I returned to the boat. The first was a carter P5001. This pump will work but there is only one inlet, whereas the original pump has 2 inlets. On the original, one inlet is connected to the fuel water separator outlet, and the other inlet receives return flow from the throttle body via a t-fitting. To use the carter pump you must plumb the line coming from the t-fitting to a spare inlet on the fuel water separator. This probably isnt hard to do if you have the right tools, but I did not.
The other pump I ordered was nearly a perfect fit as it had two inlets and can utilize existing fuel lines. However, the electrical connector is on the opposite side than the original pump. In order to install it in the fuel pump bracket in an orientation such that the inlet ports align with existing hard lines, you need to rotate it 180 degrees from the orientation of the original pump such that the electrical connector is facing away from the center of the engine. You can fish the wires coming from the relay around to connect without issue. I ordered this pump from the ROP shop and they were great to work with. I've put about 15 hours on the engines since I swapped the pump, and so far no issues.
https://theropshop.com/shop/products/el ... 023-556017
chpsk8
Has thanked: 27 times
Been thanked: 76 times
Re: 454xli throttle body injection fuel pump
Post by chpsk8 »
Dang that is a much cheaper solution to the fuel pumps I had installed in mine!
Last year I paid $299 for this one and had it put on the port motor, then this year I paid $399 and had it installed on the starboard side! Good post so people can see a cheaper solution to what their mechanic might offer. :down:
https://marineenginedepot.com/fuel-pump-high-pressure-gm-pump-with-return?gclid=EAIaIQobChMI1az52rWi6gIVDNvACh0vLgIwEAQYAiABEgJ0TPD_BwE
Post by g36 »
Thank you for posting this info, please update later if you can to let us others with xli engines know how it's going.
