New Member - First Carver '07 35 SS
Helmsman
Has thanked: 73 times
Been thanked: 42 times
Re: New Member - First Carver '07 35 SS
Post by Helmsman »
danclev wrote:QR_BBPOST
Helmsman wrote:QR_BBPOST I owned a 2006 33 SS for 4 years which is the very same boat. They changed it to a 35 SS in 2007. What Does it have, crusader 6.0 engines? If so I can walk you through changing the impellers. Easy job but I would definitely change them. I would also change the belts. I have the props (they are brand new 22x22 1.5” shaft). Sold the boat a few months after buying them as spares. Anyway, pm me and we can go through the boat a little so you feel comfortable with it. I will also be glad to have a phone conversation with you. Carver pulled the manuals a month ago. I may or may not have pdf copies I will look for, for you
Thanks! That would be great. Yes, Crusader 6.0's. First question is how to ID the right impellers and buy them. I'll dig into that. I did find the owner's guide for the 36 which is essentially the same boat I'm assuming.
I cant attach a pdf. Pm with an email, and I will send you the Crusader Owners operation and Maintenance manual. It is for 2006 and 2007. A diagram of where the impeller is for the 6.0 is on page 58, and the part numbers are on either 68 or 69 depending upon whether you have a returnless fuel system, or an FCC fuel system. I have pasted and copied from those two pages below. It is very likely that you have the returnless version which can be verified by comparing your fuel water separator to a parts picture on an ordering web site.
ON-BOARD PARTS KIT 6.0L MPI
RETURNLESS FUEL SYSTEM - ‘05 To Present RK173092A-05
Box, On-Board (1) 22433
Belt, Serpentine (1) R066027
Fuse, 20 Amp (3) R153017B
Relay, 12V, Fuel Pump, Ignition, Start (1) R130011A
SparkPlug, Set, (Platinum) (1) RP030011
Impeller Kit, Raw Water Pump (1) RP061022
Primary Fuel Filter Element, 150 Micron (1) RP077014
Filter Element, Racor Fuel/Water Separator (1) 47047
FCC FUEL SYSTEM - ‘05 To Present RK173092-05
Filter and O-Ring, Kit, FCC (1) RP080026
Been thanked: 470 times
Post by RGrew176 »
Welcome Aboard. Good luck in getting her home. Hope you have a great trip.
Post by tomschauer »
Pre trip check list on a boat new to me...
Tow boat us gold.
Plenty of fuel.
Plenty of water.
Cell phone
Vhf
Beer
More beer in case you need towed in.
cgriffis
Vessel Info: 2000 Carver 530 voyager
Post by cgriffis »
My Son owns a 35SS and needs to do some maintenance on the shower sump. Can you provide info on how best to access it?
Thks,
