I really do like my 506 but since I like to work on it myself, I find the owners manual a really useless POS. My 2006 Sea Ray 44DB manual had about 30 pages of very detailed wiring diagrams. Carver's idea of a wire schematic is a Joke! Are there additional manuals available anywhere that have more detail or even a legend that identifies circuits by the number tags on the wires. I found a #10 brown wire marked B8 paired with a B8 black ground wire in the bilge. both wires were terminated with an environmental butt splice heat shrunk to isolate. The wires are bundled next to a midship bilge pump. I am thinking it may be for an optional high water pump or alarm but with out a decent wire schematic, who knows? I started tracing it and it is part of a bundle that goes to a primary ER breaker panel but did not find the other end. Some other bilge pumps had wire tags B6 and B7 so I am guessing it is some kind of optional bilge system. The wire has no voltage so I assume it runs to the Main DC panel but just not attached to a CB. I ran out of steam before I took on the task of gaining access to the back of it to find out. Any Ideas?
Carpe Diem
DC system wire diagrams for 2000 506?
- Carpe Diem
- Been thanked: 3 times
- Been thanked: 654 times
Re: DC system wire diagrams for 2000 506?
Yep totally agree it's not much for tracing wire location just general location, but if you have the oem manuals for your boat then you got all there is.
One of the items brown wires are used to connect is any type of pump. So could be any system that utilizes a pump but the code on the wire certainly leads one to believe that it was a bilge pump option. It may have been an option never installed or something a previous owner disconnected and removed.
