No power to port side panel AFT 1983 Carver 28 Mariner
throwback2
Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys
Has thanked: 8 times
Been thanked: 23 times
Re: No power to port side panel AFT 1983 Carver 28 Mariner
Post by throwback2 »
Mccurdyj wrote:Qr Bbpost Ok thank you. Where do they hook up on each engine?
You will have to follow the battery cables,mine were across the bell housings
Mccurdyj
Vessel Info: 1983 Carver 28 Mariner
Post by Mccurdyj »
Harness was basically completely disconnected. Plugged in and fired up :-( thank you all for all your help. Could not see the back side of the harness plug because it was behind a coolant line
Mccurdyj wrote:Qr Bbpost Harness was basically completely disconnected. Plugged in and fired up :-( thank you all for all your help. Could not see the back side of the harness plug because it was behind a coolant line
Thanks for posting, it is always great to see the resolutions to these problems, generally the simple solutions are the ones......curious...was there anyone working around that area before this happened ?
