Zantrax Link 1000 monitor replacement for Freedom 25 inverter
Carpediem
Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
Has thanked: 2 times
Been thanked: 25 times
Post by Carpediem »
My Link 1000 monitor for the Freedom 25, 2500 watt inverter/charger has decided to fail. The unit still seems to control the Freedom 25 but the LED display is dim and flickers. Apparently the Link 1000 is out of production. I have not been able to discern which remotes currently in production will be compatible with the Freedom 25 inverter. Has anyone dealt with either replacing or upgrading their monitors that can shed some light. I have yet to reach out to Zantrax because what reading I have done leads me to believe that would lead to frustration.
Thanks for any input
Carpe Diem
Try to only boat where ducks don't walk
Re: Zantrax Link 1000 monitor replacement for Freedom 25 inverter
Post by g36 »
I don't know if this is what you need but post #5 says this panel worked for his unit although not the exact part you may be looking for.. The part listed is still available....https://www.sailnet.com/threads/replace ... 000.67157/
Carpe Diem
Been thanked: 3 times
Post by Carpe Diem »
g36 wrote:QR_BBPOST I don't know if this is what you need but post #5 says this panel worked for his unit although not the exact part you may be looking for.. The part listed is still available....https://www.sailnet.com/threads/replace ... 000.67157/
Thanks, I found that reference as well, I went ahead and ordered one. We will se if it works. Appreciate the help
Carpe Diem
Carpediem
Post by Carpediem »
I installed the monitor and it works fine. It is just not as informative as the Link series as it does not have the amp hours remaining functions but it gives enough basic information. I don't the boat in a way that I need the inverter anyway.
