I think it depends on where you're at in the fresh water. If you are in a smaller lake or one that gets warm, then algae can definitely be an issue. If you're in a cooler lake or on/near a river one that flows and prevents the growth of algae then it might not be much of an issue. A lot of the marinas around us it can make a difference if you're near the entrance to the marina (close to the lake) or in the back where there's more stagnant waters.Midnightsun wrote:QR_BBPOST Nothing wrong with lake water intake as long as you are in fresh water. The last 3 boats I had were lake water drawn from the factory and most are in my area. Never heard of an issue. I believe the only boats that draw from the potable water tank are those set up for salt water use as in equipped with heat exchangers.
Water lines
- Been thanked: 1114 times
Re: Water lines
- vineyardgray
- Captain
- Has thanked: 128 times
- Been thanked: 33 times
- Contact:
Re: Water lines
This looks like a compelling system for treating raw water and the lines to/from the toilet:
https://www.gobius.se/en/produkt-kategori/seasmart-en/
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
1988 Carver
3867 Santego
PCYC
