1988 Carver Santego 3867 38"
- Bbeauty
- Vessel Info: 1988 Carver Santego 3867 38'
- Has thanked: 2 times
Just registered and in the throws of
negotiating the purchase of a Carver Santego 3867
It is coming down to locating the 265 gallon fuel tank..
The current owner does not know her it is and the surveyor could not locate the tank unless he tears out the flooring.
We need advise if possible on where the tank is
located
She has one fill spout is on the starboard side and one fuel gage and no switch to chage readings so owner says it has only one tank. It has no aft cabin so engines are aft as is the generator.
Any suggestions would be appreciated.
R Gault
located
R Gault
- Been thanked: 654 times
Re: 1988 Carver Santego 3867 38"
Hopefully someone with the model will chime in . Good luck with your purchase
- Cooler
- Has thanked: 68 times
- Been thanked: 414 times
A tank that size has to be located in the center of the bilge. It is most likely just forward of the engines, maybe behind on the forward side of a bulkhead. There should be a couple of hatches in the salon or steps that give you access to tank sensor. The water tank will also be in the same area, probably just forward of the gas tank. Gas tank is metal. If you have the owners manual, there should be a diagram for tank locations in there. Good luck and welcome.
er
Cooler By The Lake
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
Bbeauty, welcome aboard and I hope all goes well on the Santego. The fuel tank is located in the middle of the salon, in front of the galley counter/bar. It is a single tank. If you move the bench on the starboard side you will find they’re the fuel fill hose connects to the tank. The tank should have a large wood hatch under the carpet that is screwed down. Your water tanks (there should be two) are a bit forward of the fuel tank and to the left of the galley counter/bar. One will been under the parkay flooring in the galley and the other hatch will be under the carpet.
Ron
“Escape Plan”
Murray, KY
“Escape Plan”
Murray, KY
- Been thanked: 492 times
Welcome aboard!
Good luck.
Good luck.
Welcome aboard. Hope everything goes well with your purchase. Keep us posted.
- GLHaulers1
- Vessel Info: Carver you
- Has thanked: 1 time
I’m a transporter and have been trying to get onto the Carver website to find the specs on this year and model so we can accurately quote the move. Does anyone happen to have the overall height from keel to highest point ( or bridge clearance and draft) for this vessel?
- ColRon
GLHaulers1, per Carver her draft is 42”. On mine the air draft is around 15’ with the radar tower installed. Over all length is 44’, 11” with a beam of 14’
Ron
“Escape Plan”
Murray, KY
“Escape Plan”
Murray, KY
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Welcome Aboard and good luck. Hope everything falls into place for you.
- dtcom
- Vessel Info: 1993 Mariner 330
- Has thanked: 4 times
- Been thanked: 3 times
See if the owner has the manual. The manuals show the location of every tank, port, and what is under each hatch.
