May Have Found Another Carver
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 467 times
http://www.pier33.com/boats-for-sale/19 ... n-8006602/
I think I may want to go take a look at it. Some friends of mine had a 27 Santego some years ago and I was impressed by the room aboard. I know its still twins but this boat should be more economical to run than my 3007 was.
What does the braintrust here think. Should I go look at it. I did request some more information from the brokerage. So, we'll see what happens.
- Been thanked: 615 times
Re: May Have Found Another Carver
- ColRon
- Has thanked: 77 times
- Been thanked: 153 times
“Escape Plan”
Murray, KY
- Been thanked: 1043 times
Didn't you have V8's in your old boat? If so then I think this would be more economical, as it has V6's and probably displaces a lot less.
I wonder if the owner is a member here. I recall someone asking for info on the helm switches, as the labels were all washed out. Probably happens on most of these boats but is easily resolved.
- Cooler
- Has thanked: 68 times
- Been thanked: 390 times
- Has thanked: 324 times
- Been thanked: 595 times
Make sure you check the stringers, they are encapsulated wood.
Weak point is the motor mount area.
Check it out.
- RGrew176
It should be more economical. The twin 4.3's vs the twin 5.7's plus the fact it is an I/O vs inboard drive system should make it less expensive to operate.
- uchu
- Vessel Info: 1988 Carver Santego 2767 - Twin Mercruisers 4.3LX with Alpha-One drives
- Has thanked: 86 times
- Been thanked: 15 times
It looks very clean too, hopefully it will check all the spec marks.
The earlier ones (like this) don't have a balance shaft, so they may shake a bit especially at idle. Don't let that scare you.
As far as efficiency, don't expect it to be a big savings on fuel compared to your 3007. It will be better, but not by a bunch.
- RGrew176
The boat is still available so I plan to call and make an appointment to see it next Saturday if it is not already covered for the winter. The Santego based on the pics and the advertisement do seem to meet most of my wants and needs.
Users browsing this forum: No registered users and 37 guests
