3608 carver
- 3608
- Vessel Info: 3608 aftcabin 1991 carver twin 454
3608 carver
Hello new to group thanks for the add I have a 1991 3608 aft cabin just recently purchased twin 454 I rebuilt port engine and running fine. Went threw top end on starboard trying to fire engine but no fuel I installed new pump still nothing problem there's 3 fuel selectors and info's not there tried getting new placard no luck there does anyone know what position levers need to be ? I believe middle is for generator
- Been thanked: 1114 times
Re: 3608 carver
A picture of the selector valves might help. Unless someone knows that specific model, they may not know the layout or configuration. Also, some things could have changed by a prior owner.
Have you checked the anti-siphon valve at the tank(s)? Do you know that fuel is even getting up to the fuel pump?
Do you just have two fuel tanks or do you have three? On my 3607 (predecessor to your 3608), I could have either engine on either tanks. Later models only let you switch between a main tank and an aux tank.
- Been thanked: 492 times
Re: 3608 carver
The fuel selector for each engine, no matter which choice is selected, the engine will get fuel from a tank, whether it be port, starboard, or genny.
Have you attempted it in all three positions.
