Isolation transformers
Charleigh
Vessel Info: 2005 Carver 56 voyager
Has thanked: 3 times
Post by Charleigh »
Does anyone know how to replace the electrical system in a 2005 56 voyager so that a 30 amp imput Will power up the electrical panels?
Re: Isolation transformers
Post by Midnightsun »
Need a little more info as to why. If you have 30a available, using dual 30a plugs on different phases with a reverse Y adapter will get you power to the boat. Not too clear on why you would want to replace the system.
Been thanked: 1114 times
Did you forget the other thread you started on this? (here: viewtopic.php?f=12&t=6513 )
There was a solution that WILL WORK posted near the end.
