Leak!
- Vessel Info: 1996 Carver 455
Leak!
Eden Isle, La
- Has thanked: 268 times
- Been thanked: 1153 times
Re: Leak!
- Been thanked: 1043 times
Re: Leak!
Yea, sure, go ahead and just rub that salt right into the wound!!! All the folks up here are just now seeing the daylight start getting longer and have to wait MONTHS before they can say those same words!!!
Oh, can't help much on the leak but good luck on finding/fixing that!
- Been thanked: 615 times
Re: Leak!
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Re: Leak!
You can remove the hoses and replace with new, but that may be a major undertaking. I would simply splice the hose and put in a double barbed fitting with pipe clamps on each side. These should not be a pressurized line and this simple fix should last for years.
Greg
Re: Leak!
Eden Isle, La
Re: Leak!
just going to replace the whole length with a hose that follows a more sane path.
Best fix by far. Adding a piece of hose or installing a barbed splice will introduce a restriction causing flow to taper off a bit. Maybe the flow difference would not matter but by changing the entire hose you know for sure it will work as intended.
- Has thanked: 455 times
- Been thanked: 1671 times
Re: Leak!
Users browsing this forum: No registered users and 173 guests
