I've either made a horrible decision or a great investment
Been thanked: 492 times
Post by waybomb »
If you decide to change the vinyl windows, simply sew the new vinyl over the old vinyl at the original thread line. Then, take a razor blade and cut out the old vinyl. Makes for a perfect fit.
572s=900hp each at 5800 rpm. 1.5 reduction. 33" cleavers. 18,000 pounds wet.
anothernewb
Vessel Info: 2000 350 Mariner
Twin Mercruiser 5.7l Horizon
Garmin 4212
Been thanked: 21 times
Post by anothernewb »
Does your fuel gauge look like this?
Last edited by anothernewb on December 9th, 2015, 10:56 pm, edited 3 times in total.
CaptBob
Vessel Info: Shopping....
Been thanked: 33 times
Post by CaptBob »
I dunno about his, but mine goes the other way!
Capt Bob!
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat.... :captain2: )
Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
anothernewb
Garmin 4212
Ahh. Not only did I fix the magic fuel gauge but I found a better way to do it.
Post by waybomb »
You know what, it certainly burns more fuel an hour than my Carver, but, it still takes about the same amount of fuel to go across the lake. One takes 3 hours, the other 30 minutes. About the same amount of fuel though.
anothernewb
Garmin 4212
Pulled the port side motor out today and tore it down. Remember when I said I tried to start it and the motor went "RUH RUH RUH Hickup... tink"?
Ouch. :banghead: And this was supposed to be the good motor. The piston was kissed pretty good too but a quick check didn't reveal any cracks. The bores all look fine with no real signs of rust. There must have just been a little bit of water sitting on a couple valves and rusted them out. The exhaust runner looks pretty bad, I'm hoping the head is savable.
There's always a bright side though.
SO MUCH ROOM FOR ACTIVITIES!!!
While the motors are at the machine shop I'll be cleaning the bilge, pulling the fuel tank, prop and propshaft as well as doing some cable/hose management. I heard back from the prop shop yesterday and both the shaft and prop were pretty bent. He said the run out on the shaft was .16". At this point with both prop shafts out I'm going to change the cutlass bearings as well. I noticed on the survey it noted that they were approaching the end of their life. The goal here is to do EVERYTHING that would require a haul out now while its out.
I got tired of lifting the generator hatch on and off and decided to pull the FireBoy off to make it lighter. I'm sure it wouldn't have been much longer before I would be cleaning that out of the engine room
Did the shop make any recommendations for the shafts? In my experience, if they are out that much, I wouldn't bother straightening them. They have a tendency to kreep back some after a while. Understandably, I doubt they'll warranty the straightening. Pricey to replace with new, but it's likely a vibration will show up eventually, and it'll mean another haul out later anyway.
anothernewb
Garmin 4212
He didn't say anything about the bend creeping back so I dunno.
Took the second motor to my rebuilder today. The head with the broken valve is toast. At this point he suggested I pick up a couple rebuilt engines from one of his suppliers. We crunched some numbers and it just makes more sense.
Does anyone know where I would find a battery charger or inverter for this thing? There's a charger under the bed for the battery connected to the bow thruster but that's all I have found so far.
Rpratto
Vessel Info: 1986 carver Santa Cruze
Has thanked: 3 times
Post by Rpratto »
Here's a picture of my 1986 Carver Santa Fe
Been thanked: 470 times
Post by RGrew176 »
I really enjoy following your story here. I think I will be just as happy as you when you launch. We all can learn much from you as you progress with your refurbishment of your yacht.
