Virtrifigo Fridge swap out
Re: Virtrifigo Fridge swap out
Post by g36 »
I started replying to you but realizef I may not be the right Greg that you meant to answer you. Anyway for me it was easy enough on my 405 to come into the salon door. I know you have different boat but you could remove the fridge/freezer door to gain more room and also if you want to change the door swing direction.
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Post by Tireless »
They have always gone through the companionway door from the aft deck to the salon. You will more than likely have to remove the doors and hinge from the refrigerators to get the in/out, easy to do. The carry it up/down with the opening to the side.
To get them on/off the aft deck, lift over the skirt wall by removing the canvass either from the side or down the stairs depending on the height of the dock in relation to your boat.
Hope this helps.
Greg
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Post by tonyiiiafl »
Helps a iot! Thank you.
tonyiiiafl
Been :angry: looking at that beautiful Fridge sitting in my office…..so I decided to plug it i. QUIET, and also cooled down pretty well. Freezer down to 10
fridge to 35 within 2.5 hours. Looking forward to getting this baby installed.
tonyiiiafl
ONE thing I notice, perhaps there is no enclosure, it does come on what seems like pretty often, but also maybe 10 minutes then shuts off. .....
My experience, around every 15 to 20 minutes cycle on and off is about right depending on ambient and material inside the fridge.....
tonyiiiafl
Probably coming in like it is because it is empty and nothing to absorb the cold. Nice unit for sure.
Tireless
Post by Tireless »
Every time I have swapped a refrigerator out to a Vitifrigo the admiral loves it. My friends that have made the switch feel the same way. The cooling is much more consistent and she can get more in it. I like them because they are more efficient and is a little easier on the batteries while on the hook.
All in all the newer technology is better than the older units that come with the boats. They appear to be more reliable.
Greg
